2003 Ford F350 6.0 stalled and now won't start
Old Dec 5, 2012 | 09:01 AM
JayJay's Avatar
Default 2003 Ford F350 6.0 stalled and now won't start
while driving on the road my truck stalled and when I tried to restart it, it would not crank over had to tow truck home, changed fuel pump, cam sensor and crank sensor but nothing still doing the same thing. Diesel machanic shop is 2 hours away this is my only ride. Help someone, batteries on the truck keeps dying to hooked it up to charger but won't charge compelety it anyone has anything solutions please I need help Thank you
Old Dec 5, 2012 | 10:26 AM
Mdub707's Avatar
It doesn't crank over? Or it wont fire? There's a big difference in the engine not starting and the engine not even cranking over. I'm assuming it's turning over, but not firing right? When you crank it over, are you seeing any smoke out of the exhaust?
Have you tried reading codes? If I had to guess, I'd say high pressure oil pump, but that's only a guess since we have nothing to go off of.
Why was the fuel pump and the two sensors changed? Were there codes thrown for those? I know on these the crank and cam position sensors will throw codes falsely when the truck is cranked over a bunch and doesn't start, but realistically they rarely go bad.
Do you have any way to monitor anything (scanner or an SCT or...?)
Old Dec 5, 2012 | 03:40 PM
bobfbigman's Avatar
If it died as you were driving then it is most likely the HPOP failed on you, very few things can make it stall as you are driving and the HPOP failing i number 1. the next would be if the FICM burnt up but I think you need to look at the High Pressure Oil Pump first.
Old Dec 6, 2012 | 12:35 AM
ArNy64's Avatar
Check your low pressure oil pump just open your oil filter housing and hold down on the plastic valve at the bottom while somone cranks the motor it should fill up with oil in probably 5 seconds. I went through the same thing before i just didnt test my low oil pump and replaced my hpop and spending more money then i needed.
