High idle and 3 cyl idle
Old Dec 4, 2012 | 04:51 PM
snowshoveler's Avatar
Default High idle and 3 cyl idle
I took my truck to the dealer and asked about getting the high idle enabled and also the 3 cylinder idle as well.
The truck is a 99 with 140 miles on it.
Has an edge juice box with edge, 4 inch stainless exhaust and bla bla bla. You get the idea.
I copied out the flash number and printed off everything.
Took it all to the dealer. Showed the service advisor the paper work. First mechanic had no idea about any of it. Second mechanic (their diesel guy) has done many of the same already and was familiar with it all. Sure.
1 hour and 169 bucks later I have no high idle but subosedly have the 3 cylinder idle.
Wouldn't think thats possible but sometimes it take a bit to learn things I guess.
And I learned my lesson.
I never thought to ask here if a cummins dealer could do this instead.
Regards Chris
Old Dec 5, 2012 | 06:09 PM
H.R.D's Avatar
I don't believe a Cummins dealer can turn it on because it is a Chrysler ECM. To my knowledge you can't have 3 cylinder idle on with out having high idle turned on. I believe it is all or nothing.
Old Dec 5, 2012 | 08:50 PM
I should have bought my Buddy a box of beverages and got him to upgrade my truck with his smarty.
Oh well, its warm here or a while yet so I won't know what was actually enabled for at least a week or 2.
Chris
Old Dec 5, 2012 | 09:04 PM
colinheitshusen's Avatar
It should all be on one flash im pretty sure. ive got the high idle and If its less than like, 30 degrees it'll kick up to 1200rpm, and 3 cyl will kick in under 10 or so. worth the 170 bucks to me if it works right.
Old Dec 6, 2012 | 12:09 AM
H.R.D's Avatar
Chris
Just an FYI the below pdf has the parameters for high idle to kick in...
File Type: pdf
Old Dec 7, 2012 | 01:09 AM
Ramitt's Avatar
Get a 39k ohm resistor and stick it in the iat sensor plug and the high idle will start after about a min. You cant have 3 cyl high idle with having reg high idle. I built my own kit to run the high idle or 3 cly anytime by flipping a few switches. Honestly for the price you didnt get a deal on that one. You can enable it with a smarty also. I called around looking to find a cheap price to get mine enabled and the cummins place couldnt do it for the fact its a chrysler ecm.
Old Dec 7, 2012 | 01:36 AM
H.R.D's Avatar
Good call I forgot about doing that.
Old Dec 7, 2012 | 04:08 PM
Started it this morning and it was just cold enough for it to go to the high idle, which it did.
The wife was very surprised, and I was pleased.
When its gets colder I think the 3 cyl idle will run too.
I called the shop today and told the service lady that it did indeed work and that I would be in to buy the technician a coffee. He did seem concerned that he couldn't get it in.
So all in all I am pleased with the "upgrade" .
Regards Chris
Old Dec 9, 2012 | 12:28 PM
RollinCoal99's Avatar
loading a smarty on your truck will enable 3 cyl and 6 cyl high idle. even when smarty is removed your ecm will still have it
john grossman
10
Jan 12, 2019 08:58 PM
CumminsCoalRoller24/7
Feb 21, 2015 10:44 PM
robbyS
13
Dec 20, 2014 04:25 PM
stephenthinnes
Dec 6, 2014 01:03 PM
jmerriman17
Nov 21, 2014 04:38 PM
