6.5 backfireing
Old Dec 4, 2012 | 04:33 PM
kylek's Avatar
Default 6.5 backfireing
backfireing?? what cud be doing this the only time it dose it if im at 2000 2500 rpm
Old Dec 4, 2012 | 05:03 PM
racer55's Avatar
Broken valve spring or misaligned rocker arm?
Old Dec 4, 2012 | 05:17 PM
kylek's Avatar
that dont sound right to me i would here something if that was the case like knocking taping somthing like that
Old Dec 4, 2012 | 05:27 PM
racer55's Avatar
Backfiring don't sound right to me-the only way a back fire can happen is if an intake valve is open during a compression or power stroke when they should be closed.
If you can figure out another way for an intake valve to be open when it should be shut I am all ears.
A broken valve spring that has broken very close to the first coil will still hold the valve shut until speeds get to high and valve float occurs.
If a plastic rocker arm retainer broke,2 nearby rockers could interfere with each other and with how noisy these engines are it is unlikley you would hear anything-you should notice a miss though.
A stuck open EGR valve could also have a symptom like a backfire if exhaust pressure got high enough.
Old Dec 4, 2012 | 06:24 PM
kylek's Avatar
it sounds more like a sputter to me
i had air in the lines and just found out the filler tube poped off put it back on and now this is happening
Old Dec 4, 2012 | 06:29 PM
racer55's Avatar
A bent or cracked valve could be part of the problem?
I can't hear the noise so I can't come up with any ideas outside of what you describe the problem to be?
Filler tube as in where the fuel cap goes?
A plugged cap vent can cause lots of running problems-miss or fishbite might be 1 of them.
Old Dec 4, 2012 | 08:11 PM
kylek's Avatar
where dose the ground go on the filler its just dangeling
Old Dec 4, 2012 | 08:52 PM
racer55's Avatar
Ground goes to the body,it is to prevent static shocks that can ignite vapors.
Old Dec 4, 2012 | 11:35 PM
kylek's Avatar
ok thanks the sound im hearing is not a backfire its more like the truck is sputtering then it stops idk what it is its driveing me crazy
Old Dec 10, 2012 | 10:50 PM
that_damn_Detroit_Diesel's Avatar
i recently had the same issue.. hard start, runs like **** and then dies.. check your lift pump or oil pressure switch
