blown head gasket? bad head studs?
Old Dec 4, 2012 | 10:54 AM
dkapp0802's Avatar
Default blown head gasket? bad head studs?
so i was talking to my uncle and he said something that got me mind turning some gears, some scary gears. he was thinking that my coolant leak that i cant find, could be head gaskets and studs. what do you think. i havnt found any penut butter in my oil anywhere so to me that kinda rules that out. what do you guys think?
Old Dec 4, 2012 | 01:52 PM
Mdub707's Avatar
Is the cap around the coolant bottle white? That's usually the first place for it to go. For as common as it is for a 6.0 to pop a headgasket, it's not terribly common for them to cross contaminate like that though. Coolant and oil really only mix when the oil cooler ruptures. I mean there's the chance the heads can crack and things can contaminate...
Do you have a tuner? Do you have ARP's in now?
Old Dec 4, 2012 | 04:54 PM
Diesel firefighter's Avatar
I had the same issue bout 3 months back my heads were goin I had the white residue around the reservoir cap so I had the head gaskets changed machines the heads added arp head studs an bought a new oil cooler cause it was bad as well.
Old Dec 4, 2012 | 05:09 PM
Red_Rattler's Avatar
High Tech Redneck
What gaskets did you use?
Old Dec 5, 2012 | 07:42 AM
Mdub707's Avatar
As far as I'm concerned, only OEM gaskets should be used. At least until someone else proves that another brand works...
Old Dec 5, 2012 | 09:24 AM
Went back with ford oem gaskets
caissiel
Sep 24, 2015 05:37 PM
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
turbodiesel123
Nov 28, 2014 08:36 PM
HE22871
Nov 26, 2014 03:15 PM
