Headlight upgrade?
Old Dec 3, 2012 | 11:30 PM
joecool911's Avatar
Default Headlight upgrade?
First off, thanks for the help with cab lights. Ordered recon smoked.
My title says my rig is a 2001, but it has 4 wheel disc brakes, so I believe that makes it. 2001.5. Seems that 2001 and 2002 are break points between headlight models. So I'm a little confused. Some say the earlier lights will fit 2002, some don't.
Searched the archives, no epiphanies there. I want halo projector lights. Don't want to spend more than necessary, but I want good ones that last and put out a good beam of light and install without too much trouble. Suggestions?
Old Dec 4, 2012 | 07:47 AM
RAW's Avatar
RAW
I have had great luck with Anzo USA's products.
Search results for: 'Dodge-RAM 2500-2001'
I don't have the projectors, but they are available.
Old Dec 5, 2012 | 06:15 PM
H.R.D's Avatar
They are the same housing from 94-02 2500/3500 minus sports package.
Old Dec 5, 2012 | 07:42 PM
joecool911's Avatar
Do the upgrades that include two headlight bulbs require any special wiring?
Old Dec 5, 2012 | 07:56 PM
RAW's Avatar
RAW
To go to the Sport lights, 4 bulbs, there is a harness required. You can build it, or buy it.
Old Dec 14, 2012 | 12:59 PM
joecool911's Avatar
Been doing a lot of research. Not impressed with what I've read about the halo, projector upgrades. So I'm now looking at a two piece sport headlight conversion. I really like the idea of having 2 sets of bulbs. Thinking that should provide better light. My truck came with a one piece el cheapo set that has a broken screw tab and shoots high.
Old Dec 14, 2012 | 01:27 PM
tiremann9669's Avatar
Cummins Crazed has a nice set of lights
Old Dec 14, 2012 | 04:07 PM
daveO's Avatar
I love my sport lights.
Old Dec 15, 2012 | 08:53 AM
joecool911's Avatar
Which sport lights do you have?
Since I don't want to engineer a system to supply full power to the additional bulbs of sport lights, is the brite box a good way to go? As I understand it would simply take a brite box and a set of sport lights to complete the installation.
Last edited by joecool911; Dec 15, 2012 at 08:53 AM. Reason: Automerged Doublepost
Old Dec 15, 2012 | 10:21 AM
RAW's Avatar
RAW
The Brite box only keeps the low beams on at the same time as your high beams. It won't work for a sport light (4 bulb) conversion.
