Smarty TNT Throwing Codes Any One Else???
Old Mar 17, 2008 | 06:28 PM
Luvnacummins's Avatar
Default Smarty TNT Throwing Codes Any One Else???
The new TNT non race tune keeps throwing p0123?? can't remember for sure right now but it is an overboost code and bob told me to get a boost fooler for that but today it threw p0148... High Pressure Common rail ????
Hopefully Bob and Marco can fix this... Do you fellaz think I should pull the TNT off???
Shane
Ok I just talked to Bob and Marco thinks I have a rail sensor issue?? Any one have troubles with these?? I had the commader and it had a wire tap on there... Could this be the problem???
Last edited by Luvnacummins; Mar 17, 2008 at 06:28 PM. Reason: Automerged Doublepost
Old Mar 17, 2008 | 06:53 PM
wildbill's Avatar
It may have severed enough wires to where it's causing enough of a voltage drop, setting a code.
Old Mar 17, 2008 | 07:09 PM
Yeah I am headed out to inspect right now...
Old Mar 18, 2008 | 05:53 PM
jmono33's Avatar
Hopefully you handle this better then you did w/ the stickers Shane... he he j/k
Old Mar 19, 2008 | 08:52 AM
staarma's Avatar
I hate wire taps for this reason. I'm not sure it's your problem but it's a good place to start. There have been a couple of guys that have had to replace their rail sensors so it isn't uncommon for that either. Sounds like a coincidence though that the rail sensor and the boost code show up with the new tune but Bob and Marco know better than me.
Old Mar 20, 2008 | 05:08 AM
Ok so the wire is frayed but not split or broken... I can see bare wire but that is it so I am thinking it's the rail sensor.... Anyone have a part number??? I am goona get one and see what that does....
Old Mar 20, 2008 | 09:12 AM
staarma's Avatar
The part number I believe is 3974092 for the rail pressure sensor. You may want to try Cummins instead of the dealer. I heard there was a huge price difference between the two. Also, Quad has a new harness available so you don't have to wire tap.
Old Mar 20, 2008 | 07:04 PM
I called the dealer today and they said $700 But I have talked to a couple of members and we're thinking it could be the stock fuel system not being able to keep up with the Stage II cp3??? Maybe a possibility... I will try cummins and the dealer's number wasn't that same number so I will call and ask...
Thanks man!!!
Old Mar 21, 2008 | 08:58 AM
staarma's Avatar
Yeah, try Cummins as I think they were around $180. I didn't realize you didn't have a Walbro or the like. Sounds like more money to spend. On second thought, I suppose that if you were constantly draining the rail it could be causing your problems. Basically the ECM tells the FCA what kind of demand pressure it needs then it checks the pressure delta between that and the rail sensor for actual pressure and if the two aren't within whatever spec they determine in the firmware then the check engine light is thrown and it will set a code. This may or may not be the case with your truck. Either way you definately need a new supply side pump with at least 30 PSI available to that modded CP3 I would think.
Old Mar 21, 2008 | 06:46 PM
Yeah I have an airdog that we are going to install within the next week or so... So... Today I go out start the truck and nothing.. No codes none at all today... Romped on it a couple of times and nada??? Im cornfused.... Hopefully though the air dog will be the fix!!!
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
CHAMP31707
For Sale
Jun 1, 2015 03:59 PM
jdepuy618
For Sale
Dec 21, 2014 05:28 PM
5.9sledhead
Price Quote - Request A Price
Oct 28, 2014 11:43 PM
