automatic trans swap from 2wd to 4wd
Old Dec 2, 2012 | 08:00 PM
dtom's Avatar
Default automatic trans swap from 2wd to 4wd
hello first i want to say this is my 1st post on here, i always search your site but finally signed up. i have a 92 dodge 3/4 ton 4x4 auto with a overdrive. im wanting to swap in a auto with a overdrive out of a 91 1 ton 2wd. what will i have to change if anything? can i just swap out the tail housing or what? also what is my tranny called in my truck and what is it called in that 1 ton.thanks for any help that you guys can give me
Old Dec 3, 2012 | 08:42 PM
dtom's Avatar
well i do want to say thanks for all the help, i thought this was a pretty easy question but i guess not. i will go ahead and post on a dodge only forum
Old Dec 4, 2012 | 11:14 AM
montepig72's Avatar
Both transmissions should be a618 also called 47rh. Not sure of any specifics on swapping the tailgousing.
Old Dec 4, 2012 | 11:45 AM
dtom's Avatar
ok thanks for the reply, i started doing ome research and i as thinking that mine was a
a518 46rh but i could be wrong what is the difference
Old Dec 4, 2012 | 01:03 PM
montepig72's Avatar
My understanding is the A518 was the gas version, although when I had mine rebuilt the shop told me there wasn't much difference between the two. They said the heavier one just had a few more clutches in the packs.
Does your 2wd have a yolk on the back for a u joint or does it have a slip yolk? I would think the tail housing is easily swapped, but you might have to swap the output shaft as well. I assume the 4wd trans went up and this is the cheap solution since you have a spare 2wd.
Old Dec 5, 2012 | 08:44 AM
Grrrr's Avatar
The 47rh didnt start until '94. The 92-93 trucks had the a518(46rh)
47rh has TC lockup, 46rh does not
Old Dec 7, 2012 | 02:33 PM
moparbubbabt59l's Avatar
You Have an A518 not a 618 the trans case is different on the diesel where the sprag attaches and the governor ect...any way.
Yes it will work you need to use the od and tail housing out put shaft ect i went from a 4x4 to a 4x2 by swaping them
Sent from my DROIDX using Tapatalk 2
Old Dec 8, 2012 | 06:15 AM
montepig72's Avatar
Thanks for the correction, I just learned something myself.
Beau_Jacques
Jun 26, 2015 12:17 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
twinboys
Feb 18, 2015 06:55 PM
mw1095mw
Jan 4, 2015 11:06 PM
wisakowsky
Oct 14, 2014 08:13 PM
