Oil leak part duce
Old Dec 2, 2012 | 05:42 PM
brand97's Avatar
Default Oil leak part duce
So I didnt want to steal the other fellas thread but I have some oil issues on my 99 dodge as well, I know the vaccum pump oil line is leaking pretty bad and am not sure how to fix that. The guy who did the tranny in it said there was a gasket on the block leaking that was a 6 hour repair which I am not seeing it. It is all on the front driverside and back soaked. Way more than the just normal cummins leak. Any suggestions??
Old Dec 2, 2012 | 07:02 PM
tiremann9669's Avatar
Are you sure it's the oil line. My vacum pump seal was leakin when I bought my truck and it had soaked the whole driverside.
Old Dec 2, 2012 | 07:17 PM
brand97's Avatar
It is drippin pretty steady off the line but maybe the seal I will look it over again, is there a seal where the pump and powersteering join or is that seal up front? Thanks again
Old Dec 2, 2012 | 08:31 PM
It's where they join, I think geno's has a reseal kit or check Gould gear and electric.
Old Dec 3, 2012 | 06:52 AM
chadcycle 2500's Avatar
Get some Gunk & clean itoff good the only way to tell its origin
Old Dec 3, 2012 | 10:44 PM
RAW's Avatar
RAW
If you have a local car wash with a engine wash or low pressure wash, you can clean off the engine. If it is leaking as bad as you say, the leak will show itself by the time you drive out of the wash bay and get parked out side.
I also had a shaft seal leak between the vac pump and power steering pump.
Old Dec 4, 2012 | 07:32 PM
The Gould kit is very good
Old Dec 9, 2012 | 07:06 PM
brand97's Avatar
I just orderedthe seal kit from gould and what an awesome guy on the other end of the phone!! So far service sell with him!! Thanks for the suggestion and my part should be here tues!! Tiremann where did you get the avitar i love it!!!
cummins Pride
Sep 28, 2015 12:11 PM
Gomerpile79
Apr 9, 2015 03:45 PM
wcrofutt
9
Apr 5, 2015 02:51 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
