Edge Fuel Pressure
Old Nov 29, 2012 | 04:26 PM
SupaDave's Avatar
Default Edge Fuel Pressure
OK. So I'm tryin' to get this edge insight digital gauges ( only, no chip, no attitude ) installed.
Confused as to where to mount the electric fuel pressure sender. I've read thread upon thread saying it should go at the VP44, but I noticed Geno's has an installation instruction for mounting it atop the fuel filter canister??? Do I need this snubber set-up with an electric gauge? Tapped banjo?
I'm stock with the exception of I have a Fass DDRP remotely mounted on the frame and the OEM lift pump has been removed.
Here's a couple of pix showing the lines on my VP44. If someone has pix of a preferred installation, any help would be appreciated.
Thanx all,
SD
Attached Thumbnails Edge Fuel Pressure-img_0723.jpg   Edge Fuel Pressure-img_0724.jpg
Old Nov 29, 2012 | 04:33 PM
H.R.D's Avatar
Place the sender at the inlet of the VP. You don't have to have one but it can help. I run my Edge without one.
Old Nov 29, 2012 | 04:56 PM
SupaDave's Avatar
HRD-
Sorry for my ignorance , but what's the hardware set-up look like to run it from the Vp based on my pix?
And also "don't need one" what?
Thanx,
D.
Old Nov 29, 2012 | 05:12 PM
H.R.D's Avatar
Don't have to have a snubber valve. The rear banjo bolt (one closest to the filter housing) is the inlet. http://articles.mopar1973man.com/2nd...overflow-valve
I would also recommend at least upgrading your fuel line from the filter to the VP, it would be best to upgrade the entire fuel line to 1/2" as well.
This also has a tap for an 1/8 npt for fuel pressure hook up. Universal Big Line Filter to Injection Pump Kit w/ fuel pressure access
Old Nov 29, 2012 | 05:42 PM
SupaDave's Avatar
H.R.D.
Copy all.
You've always been one of the first to reply to my posts and as a diesel newb, It is sincerely appreciated.
You obviously know what you're talking about.
Ordering the big line kit tonite.
Thanx again,
D.
Old Nov 29, 2012 | 05:52 PM
H.R.D's Avatar
Originally Posted by SupaDave
H.R.D.
Copy all.
Thanx again,
D.
You bet my friend glad I can help.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
2gCummins
Dec 8, 2014 06:02 PM
