Grille swap
Old Nov 28, 2012 | 08:45 PM
montepig72's Avatar
Default Grille swap
I am doing a piece by piece restoration of sorts on the old Dodge and I really like the look of the newer '92/93 grille. I am wondering, have any of you have tried to fit the newer grille into the mid 80's trucks? Mine is an '88 so it has the plain square gray plastic grille. It looks like a pretty much direct swap and the outlines look the same, but I'm a little gunshy to just buy one. Any thoughts?
Old Nov 28, 2012 | 08:55 PM
H.R.D's Avatar
Have any friends with one, that would be the best way to tell with no money involved.
Old Nov 28, 2012 | 10:42 PM
1993firstgennewbie's Avatar
Haha I prefure the older grills, the 92-93 grills are sucky plastic pieces of ****. The chrome peels , they crack easy, and they are pretty expensive. I've always wondered if any of the older grills would mount to my truck with the intercooler. I really like the 1979 with the double headlight and it's metal
Old Nov 29, 2012 | 12:47 AM
1stgenblowingsmoke's Avatar
Won't work without modding the support or using a early 91 rad support.
Old Nov 29, 2012 | 06:03 AM
montepig72's Avatar
Thanks that's all good info. I figured it would "fit" but the mounting holes in the core support were my main concern. And your right, scrapping my aluminum grille for a plated plastic one would be a bit of a shame.
Old Nov 29, 2012 | 10:33 AM
do you guys think it would be possible to get this grill on my 93 I pretty much want to do the oppisite as OP
Old Nov 29, 2012 | 11:16 AM
Screamin' Metal's Avatar
A little grinding here, a little drillin' there...a love tap here and a poke there...Just gotta have the right frame of mind and the willingness to use it. Piece o cake....gotta learn to love challanges...
Great looking truck!
Old Nov 29, 2012 | 12:38 PM
firstgenfreak93's Avatar
The body on my truck is from an 87 w250 because the original 91 body was two tone...blue and rust..it was bad...the 91 grille fit on no problem
Old Nov 29, 2012 | 05:39 PM
montepig72's Avatar
Look closer at that 78ish, and I think that bodystyle is alltogether different. The fenders are more rounded and they lack the creased body line at the top. The marker lights appear to mount in the body, and not the grille. I would love to see someone put that grille in a newer truck, but I say no way it bolts right in.
Old Nov 29, 2012 | 05:42 PM
bladeyamaha's Avatar
That would be sick!
