BD-Power Visit - BD-Power
New 6.0L products
Old Nov 28, 2012 | 12:16 PM
Blair@BD's Avatar
FormerVendor
Default New 6.0L products
Keep your engine oil to water cooler system flowing and prevent potential engine damage with BD’s Ford 6.0L Coolant Filter Kit. Residual powder from engine castings and hoses, and, the anti-freeze breaking down from high exhaust temperature creates a plugging slurry which can cause the the engine’s coolers to plug.
The easy-to-install kit is mounted in-line with the engine coolant hoses and comes complete with filter head, spin-on filter, mounting bracket, hoses, clamps, fittings, mounting hardware and a bypass valve for easy change of filter
A failing lift pump will not only cause sub-standard performance, it can cause costly damage to the injection system. Keep tabs on your truck’s fuel system with the BD low fuel pressure LED kit, which incorporates a red or amber LED that illuminates if lift pump pressure falls below spec. Inexpensive protection and easy installation
carid
Diesel Bombers Sponsors
Mar 20, 2015 08:03 AM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
Dec 10, 2014 08:10 AM
Nov 6, 2014 08:10 AM
Oct 13, 2014 08:10 AM
