need a wiring schematic?
Old Nov 28, 2012 | 12:08 PM
BarryB's Avatar
Default need a wiring schematic?
The PO of my truck has a wire coming from the alternator fuse out under the hood to a pink/striped(blue?) wire under the dash. Its the truck in sig.
I have also wondered why when the truck is on/ running I do not have to hit brake pedal to put in gear. wondering if this wire is a jumper for it.
Curious of what that wire goes to anyways, instead of just unhooking it and seeing if anything changes.
Thanks in advance.
Old Nov 28, 2012 | 12:58 PM
chadcycle 2500's Avatar
You DO NOT have to press the brake on 2nd Dpdges to take them out of park,once the isturned 1 click the lock position the gear select lever will move
OOOPS!! once the key is turned 1 click from locked position the gear select lever will move
Last edited by chadcycle 2500; Nov 28, 2012 at 12:58 PM. Reason: Automerged Doublepost
Old Nov 28, 2012 | 07:37 PM
BarryB's Avatar
I did not know that. now that really gets my curiousity up about what the heck that wire is there for. Now I really want the wiring schematic.
ofelas
11
Aug 12, 2015 07:23 PM
yzrider250
Diesel Engine Conversions
Aug 10, 2015 11:33 AM
Forks diesel nut
Jul 27, 2015 12:19 PM
RayRay4991
Mar 17, 2015 10:01 AM
stillcummin
Nov 4, 2014 06:21 PM
