95 12 valve cummins
Old Nov 27, 2012 | 09:19 PM
zackas94's Avatar
Default 95 12 valve cummins
I have a 1995 12 valve and im not sure how to change the fuel filter. I know its a screw on but what connects to the bottom of it and how do i disconnect it?
Old Nov 28, 2012 | 07:06 PM
olsmokey's Avatar
thats a wire and it will on plug 6 to 8 inches or so under the filter. unplug that unscrew the filter and drain the fuel. make sure to use the new gaskets. you can either refill the filter with fuel then screw it back on or screw it back on dry and push the primer 50 or so times and it should fire right up. hope this helps.
Old Nov 28, 2012 | 07:22 PM
BADJUJU95 12V's Avatar
it is water sensor unplug the pigtail and just unscrew it but be careful they like to split if it has any age on it
12 valve 97
5.9L 12V Performance
21
Jan 27, 2016 04:59 PM
PeteBug
Jun 11, 2015 12:16 PM
river rat
May 18, 2015 05:04 PM
Bigsexyhick
Diesel Engine Conversions
Mar 19, 2015 09:57 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
