24v P7100 conversion
Old Nov 26, 2012 | 10:44 PM
BowHunterLegend's Avatar
Default 24v P7100 conversion
I have a 2001 Dodge Cummins 24v and i wanna do a p-pump converstion. I have a complete 12v cummins motor. Any instructions on how to do this? I am very good with 12v motor. not so hot with 24v but just need some 24v help. Also will i need anything that is not on the 12v motor? Like any custom stuff?
Old Dec 6, 2012 | 10:44 AM
99flatbed's Avatar
I have heard you can use stock lines to start off with and use a break line bender to shape them, I am wanting to do a swap as well and that is about all I have learned so far
Old Dec 6, 2012 | 11:30 AM
Farmboy 2.0's Avatar
Ok you will need the front cover off the 12 valve, P-Pump Gear, Cam Gear of the 12 valve engine, and 12 valve timing kit. You will to build a pump mount bracket to support the heavy pump IMO, oil feed lines for the pump, APPS trhottle linkage setup. You can either try and build one or buy one for like $175. You will also need a P7100 swap cam adaptor to make sure the charging system, and tach on the 2001-2002 trucks. And the lines you can either buy and or modify your stock 12 valve ones. Just make sure you keep them all equal length.
CGwill
Apr 21, 2016 10:13 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
gyayo2012
13
Jan 14, 2015 11:29 AM
mt grizzly
Diesel Engine Conversions
Dec 31, 2014 12:13 AM
sotomo
Nov 24, 2014 07:29 PM
