wierd noise/knocking then goes away?
Old Nov 26, 2012 | 09:05 PM
novapat's Avatar
Default wierd noise/knocking then goes away?
hey im new here and you guys have helped me alot in my 89 chevy suburban convertion/to 1st gen 12 valve. I was coming home yesterday pulling my 26 ft toyhauler and after a steep grade it was just getting level and i hear this noise of like a rod knock and i pull over and the truck was ideling real low and black smoke then dies. I wait a minute and restart it and it seemed like it had a hard time turning over and then fires up and is fine?? wtf? exhaust temp never went over 1150 trans was 170 water temp 170 oil presure 45!! everything normal. One other thing thismorning it started then died (cold) restarted it and it was fine. it has never died like that when cold this thing turns over less than a turn and its running? its a new engine hamilton cam ddp inject denny t pin m&h timing advance 60 mm compressor upgrade! any ideas guys?
Old Nov 26, 2012 | 09:50 PM
bladeyamaha's Avatar
Sounds like a fueling problem to me, not sure though.
Old Nov 26, 2012 | 11:04 PM
BC847's Avatar
How cold is it at your house, and when's the last time you replaced the fuel filter?
Old Nov 26, 2012 | 11:22 PM
novapat's Avatar
Its only in the 40s! I did the fuel heater delete kit and filter without the sencor last week! a person on this site told me about the delete kit and i did that! One thing i did was just install the delete kit and the new filter i didnt bleed the system! could there be air somewhere? I have driven it prob 175 miles since then!
Old Nov 27, 2012 | 11:13 AM
May not have been a good idea to do the fuel heater delete if you live in a cold weather area.
Old Nov 27, 2012 | 03:29 PM
1993firstgennewbie's Avatar
The fuel heater does nothing except leak. If you look at your motor there is about 5 feet of fuel line after the heater that is full of fuel and is not heated it makes no sense to have a fuel heater
Old Nov 27, 2012 | 04:21 PM
The intake keeps that heated, supposedly, after the engine gets hot. Keeps the fuel stable.
If you replace the o-ring above the fuel heater, it does not leak, most of the time.
Last edited by bladeyamaha; Nov 27, 2012 at 04:21 PM. Reason: Automerged Doublepost
Old Nov 27, 2012 | 05:23 PM
Yeah when the engine is warm. the fuel heater is for starting and isnt on all the time
Old Nov 27, 2012 | 05:55 PM
novapat's Avatar
I have never had the fuel heater hooked up! it just leaked and made a mess. I dont live in a cold area!
Old Nov 27, 2012 | 06:04 PM
BC847's Avatar
- The fuel heater is there so as to prevent particles of wax (from cold diesel) from plugging the fuel filter.
- The warm fuel returning from the injection pump and injectors, flows back to the tank and warms the fuel in the pick-up reservoir (in the tank).
