odd truck problems. NEED HELP!!
alright i have a 95 cummins that recently started giving me some wierd problems.
As i drive my truck it'll run fine and every thing until i shut it off. once i start it back up, the check engine light flickers, the charging system stops working, rpm gauge stops working, and overdrive stops also. Ive replaced the crank sensor and spaced it right at .050 like everyone say. So what else could be the problem? i could really need the help thanks guys
often times the new crank sensor could still be malfunctioning. it would also be a loose pin in the harness on the pcm. also have you checked the wiring from the sensor up. if the crank sensor is bad or not getting power the pcm doesnt even know the trucks running so no tach no overdrive or lockup and no charging
but its weird how itll run fine and everything for however long.. but as soon as i turn they key off and go to start it back up. every things all types of messed up until i let the truck sit for awhile than itll be fine again.
bump
bump
Last edited by cummin2fast; Nov 27, 2012 at 11:32 AM. Reason: Automerged Doublepost
i was having the same issue with my truck, i checked and regapped the sensor and it was good. so i thought the wires could be bad but the continuity was fine. so i checked the power out of the pcm to the sensor. it is pin A17 purple and white wire. only getting a 10th of a volt. its to be 5. pulled the connecter apart to check the 2 grounds and the battery plus and ignition power both good. checked a few other of the pins that run 5 volt and the same 10th of a volt. i have a bad pcm
checking that is the easiest way to find out if its the sensor still or the pcm
get on ebay is search whatever year your truck is for mine i typed (1996 dodge cummins pcm). a company called auto computer exchange sells them programmed for your vin and mileage with the latest updates from chrysler for $224 lifetime warranty just gotta send your in for a core when you recieve the new one. i just got mine worked mint very impressed.
doublehbar
13
Aug 9, 2015 12:35 AM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
