crank case oil cannister...maybe leaking
Old Nov 23, 2012 | 11:33 AM
rhitch's Avatar
Default crank case oil cannister...maybe leaking
not sure if I need it , I'm coating bottom side and tailgate 235K miles runs great all stock except steering stabilizer.
Old Nov 23, 2012 | 12:16 PM
RAW's Avatar
RAW
You talking about the canister at the front of the engine, correct? It is something that need to be in place. Most guys remove the bottle, and use heater hose to extend the blow by hose to axle level.
Old Nov 23, 2012 | 12:45 PM
rhitch's Avatar
little plastic bottle up front seems empty ,am trying to trace leaks. thanks
Old Nov 25, 2012 | 12:28 AM
blacksally's Avatar
i dont get what the little bottle is??? the road draft tube??, i just plumbed mine to rear oh cab
Old Nov 25, 2012 | 05:31 PM
rhitch's Avatar
Took bottle off cleaned it about 1/3 full of oil, also took crankcase canister off cleaned and put back on .I've got a good run to coast of Carolina's to check it out. Thanks for everyones help
Old Nov 25, 2012 | 07:00 PM
jake74's Avatar
Check the bolts that hold the front Timing cover to the block they work loose over time and cause bad leaks around the front of the engine.
Durtyd09
Nov 11, 2015 01:43 PM
soco
Jul 27, 2015 06:06 PM
coors_man_2005
Dec 15, 2014 10:23 AM
musikagod
11
Nov 30, 2014 07:22 AM
steves2500diesel
Oct 14, 2014 05:36 PM
