Auxiliary driving lights
Old Nov 23, 2012 | 02:04 AM
Rigwelder68's Avatar
Default Auxiliary driving lights
Does anyone know how to keep the auxiliary driving lights on while the high beam lights are on with out completly rewiring them?
Old Nov 23, 2012 | 09:44 AM
HeavyAssault's Avatar
Built in bypass from Ford. It's going to take some thinking.....
Maybe figure out where the relay is and cut that high beam feed circuit out.
Old Nov 23, 2012 | 09:31 PM
07black250's Avatar
I'm not sure exactly how our trucks work but I had an 05 jeep wrangler that I had a mod for this all it amounted to was pulling the relay out and bending one of the prongs where it didn't make contact and plug the relay back in. After doing this the fog or aux lights worked just like normal except they didn't go off when I changed to my high beams it was one of the best mods I did. I can't remember which number on the relay was needed to be bent but ill try and look it up and post back.
Just seen on the org where for these trucks there is a wire behind the fuse panel in cab that must be cut and grounded but it only list for 05 and previous not sure if it would work on 06 or 07 if someone else knows please chime in. The wire they used was green with black tracer but I have no idea if its the same on all years or anything so please don't take my word for it.
Last edited by 07black250; Nov 23, 2012 at 09:31 PM. Reason: Automerged Doublepost
Old Nov 23, 2012 | 10:23 PM
RanchhandTCR's Avatar
When I did this on my truck I just bought a kit with a relay and spliced the trigger wire into the high beam wire in the headlight socket so they come on with the high beams. Im not sure about how well this would work for a ford.. but this is what I did and been working for awhile now and love em.. Plus its illegal not to have lights come on with high beams if you use them on highways..
Old Nov 24, 2012 | 09:13 PM
joshbaker's Avatar
ranchhand what do you mean by "Plus its illegal not to have lights come on with high beams if you use them on highways.. ". In Virginia by law you are not allowed to pass yearly vehicle inspection if the fog/driving lights can turn on while the high beam is on.
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
carid
Jan 6, 2015 06:28 AM
bypass-21
Jan 3, 2015 04:47 PM
carid
Nov 10, 2014 02:15 AM
