Dual battery circuit
Old Nov 22, 2012 | 10:54 PM
dkapp0802's Avatar
Default Dual battery circuit
Does anyone know the circuit for the dual battery set up? Or how to find a diagram for it? I'm trying to make 28 volts for my light bar.
I though about just running them in series but that can't be good for the charging system or everything else
Old Nov 23, 2012 | 07:35 AM
RAW's Avatar
RAW
You would be better off buying a 12 to 24 volt converter than messing with getting 24 volts from the batteries. How many Amps does you light bar pull? One of these should do the trick, and be much less of a headache.
Samlex Step 7 DC to DC Converter 7 Amp| ChargingChargers.com
Samlex Step 10 DC to DC Converter 10 Amp| ChargingChargers.com
I don't know anything about that website, or its products, just posted that as an example.
Old Nov 24, 2012 | 10:58 AM
Mdub707's Avatar
What the heck light bar are you running that you need 28V for it???
I wouldn't change anything on the factory side, you're going to run in to all sorts of problems.
Old Nov 25, 2012 | 12:13 PM
dkapp0802's Avatar
I was thinking about just finding a battery on Craigslist and hook it up in series with the aux battery and them run a diode in series with it so it doesn't back feed and take out the good batteries,
The light bar is a military aircraft grade one
Old Nov 25, 2012 | 01:03 PM
RAW's Avatar
RAW
Your in to a world of wiring and headache doing it that way. A 12v to 24v adapter is the way to go. A 12 volt alternator won't change a 24 volt system. You can't charge both batteries with a 12v alternator either.
Old Nov 26, 2012 | 05:37 PM
dkapp0802's Avatar
you can do it, im going to need a few diodes though and its going to be difficult. im going to check out some inverters. the light bar is bad *** so i def want to put it on. well see
Flash123
Ford Powerstroke 08-10 6.4L
Jun 25, 2015 10:19 PM
robbyS
Apr 16, 2015 02:22 PM
carid
Diesel Bombers Sponsors
Dec 4, 2014 05:06 AM
Kentonjl
Sep 30, 2014 07:22 AM
