Won't shift into overdrive?
Old Nov 21, 2012 | 08:05 PM
olsmokey's Avatar
Default Won't shift into overdrive?
i just had the 47re completely rebuilt in my 97'. today was the first time i drove it. the speedo and tach arent working and it wont shift into overdrive. Any help would be much appreciated.
thanks!
Old Nov 21, 2012 | 08:34 PM
sweetv8s10's Avatar
Maybe crank sensor check and see if your a/c works if the a/c clutch dont engage then I would say thats the problem.
Old Nov 22, 2012 | 07:04 PM
olsmokey's Avatar
no a/c on the truck
well the truck has another symptom-alternator is not charging which was nice to find dead batteries at 5 this morning 15 degrees out. come to the conclusion its either the crank position sensor or the pcm.
Old Nov 22, 2012 | 10:25 PM
sweetv8s10's Avatar
Im almost 100 percent sure its the crank position sensor because my friend had the same problem and he changed the pcm first and it was the crank sensor so he was out alot of money for nothing so I would start at the cheapest part first but thats just my opinion.
Old Nov 23, 2012 | 01:04 PM
olsmokey's Avatar
do you know were to get one? i called my local motor supply and they dont even list the part
Old Nov 23, 2012 | 01:23 PM
sweetv8s10's Avatar
What the crank sensor?
Old Nov 23, 2012 | 03:34 PM
olsmokey's Avatar
yes. its not technically a crank sensor its an "engine speed sensor". the parts stores kept trying to sell me the vehicle speed sensor. tried for about 15 minutes to drill it threw their head that wasnt what i was looking for...
AKDodge
May 14, 2015 12:52 PM
EverettsGMC
Mar 29, 2015 05:42 PM
FF131
9
Mar 26, 2015 07:06 AM
rabidrabbit
Mar 6, 2015 03:47 AM
Canadiancummins93
8
Dec 10, 2014 09:03 PM
