Problem with my Airdog 2
Old Nov 21, 2012 | 11:34 AM
Mr Stubs's Avatar
Default Problem with my Airdog 2
All packed up for the 9 hr holiday trip. Went to start my stock 01 (only mod is the Airdog) and didn't hear the lift pump cycle before starting.
Checked the 20 amp fuse. It was blown. Replaced to no avail. Checked for power at the pump and had none. Jumped the relay (red to yellow wire) and got power to the pump. Ran to the parts store and picked up a new relay.
Problem is that I still can't hear the pump cycle with the new relay or with the relay jumped.
Any other ideas or suggestions for me to check or look into?
Old Nov 21, 2012 | 11:38 AM
RAW's Avatar
RAW
How is the ground for the pump? The power needs a return to complete the circuit.
Old Nov 21, 2012 | 01:11 PM
Mr Stubs's Avatar
Both power and ground are visibly fine. They are connected to the driver side battery posts.
Old Nov 21, 2012 | 01:16 PM
RAW's Avatar
RAW
It is possible the motor is stuck. You could try tapping on it while power is supplied to see if it will break loose. Otherwise, the motor may be failed.
Old Nov 21, 2012 | 02:41 PM
Mr Stubs's Avatar
Thanks... I will give that a try when I get back.
Old Nov 24, 2012 | 08:36 AM
400sbk25's Avatar
Mine did similar thing and had to call pure flow to get a new pump and motor....
Old Nov 30, 2012 | 06:27 PM
Mr Stubs's Avatar
Talked to Josh at Airdog on Monday. New pump is in the mail.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
thurobred1320
May 5, 2015 09:26 PM
Dadslb7
Dec 9, 2014 11:05 PM
