Cold Air Intakes?
Old Nov 21, 2012 | 10:12 AM
dajain's Avatar
Default Cold Air Intakes?
I am thinking of doing a cold air intake (exhaust will be next) and have heard thru various sources that the K&N system is junk. Is that true, and if so, why?
I also did a quick search on E-Bay and there are several various types on there, as if that is a big surprise. But one I seen is just an aluminum tube with a cone filter on the end. Hell, I can build on of them and save about $150. But, is that type of setup dangerous for my motor?
I can imagine as long as there is suffiecient air flow and not too much restriction, there shouldn't be a problem.
Please let me know if I am thinking right on this one and any suggestions or comments would be appreciated.
Old Nov 21, 2012 | 10:39 AM
95powersmoker's Avatar
Yes you could build one and save yourself a few bucks. That's how it is with everything... I run a tymar setup. You can look it up on riffraff diesels website. Im on my phone so i can't link it for ya. K&n filters aren't that great because most run the drop in style filters and those boxes don't seal great. The tymar system uses a donaldson filter which is a dry filter and its huge. Plenty of airflow with good filtering.
Old Nov 21, 2012 | 10:40 AM
CSIPSD's Avatar
Riffraff Diesel: RDP 6637 Filter Kit
All the air you could ever need.
Old Nov 21, 2012 | 11:13 AM
dajain's Avatar
That is the price range that I was thinking. I'll look more into this system. What kind of gains did you get with yours?
Those other systems that I was looking at started at $170 and went up. If I was trying to make a show truck out of her it would be worth it, but I rescued her from an oil field worker and just want her to pull like she should and a maybe a little more.
So, the only flaw on the K&N's is the housing set up? There is no issue with the filters themselves pertaining to the PSD?
Old Nov 21, 2012 | 11:47 AM
CSIPSD's Avatar
The main issue with the K&N filters was there sealing to the factory box. The filter media is the same type and thickness of AFE, S&B and like.
I dont have the Riffraff intake, however I know many that do. No intake is going to give you anymore HP or TQ. The factory set up flows more then enough for the stock injectors.
Its a building block for more mods, but it will not give you any noticable increase.
Old Nov 21, 2012 | 01:57 PM
dajain's Avatar
I do understand how just the intake will not make HP ot TQ,but I do plan on making a few more mods to complete the minimal upgrade.
The reason why I was looking into the cold air if because of the breathability. I do plan on upgrading the down pipe & exhaust and therefore an increase in the air infow couldn't hurt.
I figure the turbo is just like a motorcycle. You can't open the pipes without opening the throat. Without doing both just defeats the purpose of just opening the pipes.
Mainly, I will be doing the few small & cheaper mods, replacing some old & worn out parts, and would love to hear what I can do cheaply to do this. The truck has a hard 250K miles on her and don't want to go too far until I feel comfortable with sticking some good money into her.
The $70 CAI would compliment the exhaust I am going to put on, but if I can do it cheaper by doing home made... Just wanted to insure that doing a home made "straight" pipe with a filter on the end wouldn't hurt the motor.
I do plan on getting a 6 position switch for her too in the future and that will probably be the extent of the mods except for little tinkerings that I can do.
Love all the input, thanks for the responses.
Just curious, what is the fuel pressure supposed to be at the schroeder at idle and above? I was going to check what pressure it is but never got around to it. With this many miles, I do want to see if my FPR is getting weak and needs a BB in it
Old Nov 21, 2012 | 02:02 PM
CSIPSD's Avatar
Anywhere from 50-70psi is fine.
Old Nov 21, 2012 | 07:45 PM
Like Joe said, 50-70 psi at idle is ideal...
Old Nov 21, 2012 | 07:58 PM
dajain's Avatar
I just haven't gotten down to buy a tire gauge (to ruin testing fuel) and that is why I don't know the current pressure.
If the pressure is low, what kind of boost can I expect to get from the BB trick? Keep in mind, if the pressure is good, I don't plan on doing that mod. Last think I wannnt to do is over pressure and damage something
Old Nov 28, 2012 | 08:55 AM
dajain's Avatar
With the K&N filters, I just heard the oil for the filters will plug up sensors on the motor. It doesn't make sense due to: Intake thru turbo to compression where one would think it would burn up.
Is this a problem with the early powerstrokes and K&N filter oil?
