Which Fuel Lines To Get?
Old Nov 20, 2012 | 08:52 PM
jdepuy618's Avatar
Default Which Fuel Lines To Get?
i have a 2000 ram 3500 24v 2wd. i just bought a fass 150 hd w the bigger filters. it didnt come with the fuel lines so i might as well get 1/2" lines from the get go. where do i get them and what kind. i see some are single return and some are double return line lits. what do i need and where do i get it? i know this is a total newb question, but i am learning. thanks in advance.
P.S. i plan to also install a fuel tank sump (the kind you dont have to drop the tank) at the same time if that changes anything.
Old Nov 20, 2012 | 08:57 PM
RAW's Avatar
RAW
The only place I would put 1/2" line is between the tank, and the inlet to the pump. Besides that, 3/8" line will provide all the flow you need.
Check out Vulcan Performance, they have a lot of fuel system components:
Fuel Systems
Old Nov 20, 2012 | 09:17 PM
jdepuy618's Avatar
okay. thank you. what about the dtt fuel line kit on Alligtor Diesel Performance. will that one work for me?
Old Nov 20, 2012 | 09:37 PM
RAW's Avatar
RAW
I believe that kit would have what you need. It's designed to go between the tank and lift pump, lift pump to fuel filter, and fuel filter to VP44.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
Gm3500
May 7, 2015 11:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
