what is this?
Old Nov 20, 2012 | 05:48 PM
willstruck's Avatar
Default what is this?
The rod below the paperclip, it's threaded like something adjustable, and has two nuts that would be jam nuts. The rod is bent to hell, so I need to know what it's called to get a new one, and how to adjust it.
Nevermind the paperclip, it's replacing a missing cotter pin on the rod that hangs down from the AFC stuff...
Old Nov 20, 2012 | 07:34 PM
gyayo2012's Avatar
throttle rod
Old Nov 20, 2012 | 07:59 PM
willstruck's Avatar
Thanks! I'll do a search on it, but anyone with info on how to set it, chime in!
I found there was a recall, and my VIN was listed. But it seems like it's the rod end that's changed from plastic to metal in the recall. I guess I'll call tomorrow, see if they did the fix on my truck yet, if not they do replace the rod in the recall...
Old Nov 20, 2012 | 08:37 PM
RAW's Avatar
RAW
I would imagine make it just tight enough that it removes almost all the play from the pedal.
Old Nov 20, 2012 | 09:06 PM
willstruck's Avatar
Someone on an old thread said something about setting the idle with it, too. I'll order the threaded rod if the recall falls through, and figure it out.
Looking at this diagram, mine is backwards!
Last edited by willstruck; Nov 20, 2012 at 09:06 PM. Reason: Automerged Doublepost
Old Nov 21, 2012 | 08:00 AM
gyayo2012's Avatar
i wouldnt set the ide with it there is an idle screw behind the rod socket there, you adjust the idle from there i think its a 10 and 12mm iirc
Old Nov 21, 2012 | 02:56 PM
willstruck's Avatar
Can anyone post pictures of their throttle rod, to verify if mine is the right way, or if the diagram is the right way?
