How much HP???
Old Nov 20, 2012 | 12:42 PM
firstgenfreak93's Avatar
Default How much HP???
Ok so with my pump turned up, denny t stage 2, cold air intake, and 4 inch exhaust how much power should my truck be putting out...with out the exhaust and pin, i can make 16 lbs of boost...will that go up as well??
Old Nov 20, 2012 | 02:04 PM
tampabaybill's Avatar
Old Nov 20, 2012 | 05:19 PM
bladeyamaha's Avatar
Yeah on the HP, you may go up to 20 PSI.
Old Nov 20, 2012 | 07:36 PM
92betsy's Avatar
How much is the pump turned up? Is it a 91 or 91.5? 91 non/ic bigger injectors, 91.5 ic smaller injectors, which makes for a big difference in the free power mods. With mine having a BHAF, fuel pin, 4" turbo back, fuel screw all the way in = 25psi of boost, before 4" it was 28psi.
Old Nov 20, 2012 | 07:51 PM
I can hit 24 actually when my injector pump isn't leaking everywhere!
Old Nov 20, 2012 | 08:01 PM
1stgenblowingsmoke's Avatar
My 93 VE used to hit 42. My 90 with a 5 speed hit 32 with pump turned up, exhaust, intake, turned fuel pin. and that's about it. My p-pump only makes 35 but has more topend.
boost is just restriction of the airflow into the engine.
Old Nov 20, 2012 | 08:36 PM
92betsy's Avatar
You forgot to mention the 93 had aftermarket injectors. I think he is more or less wondering what similar setups produce for boost.
Old Nov 20, 2012 | 09:47 PM
X2
Yeah, but that P-Pump is putting out more fuel at top end Josh, he's looking for info on the VE setup.
Last edited by bladeyamaha; Nov 20, 2012 at 09:47 PM. Reason: Automerged Doublepost
Old Nov 21, 2012 | 09:47 AM
No ****. 16psi is stock.
Old Nov 21, 2012 | 10:11 AM
1993firstgennewbie's Avatar
Im getting 39psi out of hx35 and I used to get 32psi out of the h1c 16 psi is not that much have you made sure all your intercooler boots are tight
