I just broke something NEED HELP ASAP
Old Nov 18, 2012 | 10:07 PM
Smarty=Cummins's Avatar
Default I just broke something NEED HELP ASAP
Well tonite I was heading home and was passing somebody n all at once a big boom in the transmission and now it wont move in any gear but I have park any ideas.
Old Nov 19, 2012 | 10:49 AM
RAW's Avatar
RAW
Pull the dipstick and see what it looks and smells like. If you rev it up to 2500 in gear, does anything happen? When I lost a snap ring, I lost all but 1st and 2nd. Reving to 2500, I was able to get it to creep in reverse.
Old Nov 19, 2012 | 11:03 AM
Ok I will try that n let u know Wat happens
What does the snap ring hold.
Last edited by Smarty=Cummins; Nov 19, 2012 at 11:03 AM. Reason: Automerged Doublepost
Old Nov 19, 2012 | 11:05 AM
RAW's Avatar
RAW
The snap ring I broke was for the forward clutch. I think your into something more extreme.
Check oil level with the engine off, and while its running. If it is the same level, it may be an input shaft or flex plate issue.
Old Nov 19, 2012 | 06:22 PM
I'm thinking it's the input shaft
Well checked the fluid with the truck off n it was like brand new cause I change it a month a go. Turned the truck on and it went down to ok Mark witch is good. Put it in reverse n it would only go up to 2000 Rpms, put it in park n it wouldgo to 3200 Rpms put in low n would only go up 2000 Rpms so Idk whats going on there so where do I look from here.
Last edited by Smarty=Cummins; Nov 19, 2012 at 06:22 PM. Reason: Automerged Doublepost
Old Nov 19, 2012 | 06:36 PM
RAW's Avatar
RAW
A bad feeling in my gut tells me you broke a planetary gear set. The bang, not being able to move, I bet it load the engine up when it's in gear and you apply throttle?
If this is the case, your going in deep. I hope it's something lesser and someone more aware of these transmission than I can try to help you out.
Old Nov 19, 2012 | 06:58 PM
Ya its not good going to take the tranny out tomorrow nite n send it to the transmission shop but how is it putting a load on it.
Old Nov 19, 2012 | 07:03 PM
RAW's Avatar
RAW
Through the torque converter. It's like your doing a brake stand, without the tires turning.
Old Nov 19, 2012 | 07:11 PM
I see well I will keep u updated on whats going on.
Old Nov 21, 2012 | 09:54 PM
Well got the tranny out tonite n I cant get the torque converter off any ideas.
