HELP! truck died
Old Nov 17, 2012 | 06:22 PM
Rayrod's Avatar
Default HELP! truck died
on my way home cruzing at normal speed 5th gear and all of a sudden it just craps out and the engine dies. no noises like the engine exploded or anything. also dident sound like it ran out of fuel. just died. truck ran flawlessly never had a problem. so it dies and the engine light comes on. towed it home checked lift pump and its fine. checked injector pump and fuel did come out of the line. Anyone heard of or had something like this happen??? i think it might be something electronic?? idk
thanks
ray
Old Nov 17, 2012 | 10:19 PM
luckyjoe704's Avatar
Going through the same dilema. Had 15-16 psi on both sides of the fuel filter canister, so the lift pump is fine, and fuel comes through the injector lines, but it "WON'T" start. From what I understand, it's got be coming through the injectors line with high pressure to start. I'm new to diesel's so it's learning process for me. Go through the 3 step process on Blue Chip's website....pretty easy. May be a seized rotor in the IP?
Old Nov 17, 2012 | 10:51 PM
H.R.D's Avatar
Check for codes yet?
Old Nov 18, 2012 | 09:23 AM
RAW's Avatar
RAW
Does the tach show speed while cranking?
Old Nov 18, 2012 | 12:10 PM
Rayrod's Avatar
no i havent checked the codes or checked to see if the tach shows speed while cranking. i will check that today. what could i mean if the tach comes up while cranking?
also when i check the injector lines the fuel should just be coming out of one line at a time??? i pulled the third injector line of and it had lots of fuel maybe not enough pessure? like luckyjoe704 said. wondering if it is just the injection pump. gota check the codes today though
Old Nov 18, 2012 | 12:35 PM
RAW's Avatar
RAW
If the tach shows no speed, it its likely your crank position sensor failed. The computer needs this signal to know where the pistons are, and when to inject fuel.
Old Nov 18, 2012 | 01:14 PM
Rayrod's Avatar
checekd the tach. it is showing rpm while cranking over. dont have a device to check the codes so i will have to get my hands on one throught the week here. im just confused because the truck ran perfectly fine and out of the blue it happened.
thanks for the help
Old Nov 18, 2012 | 01:25 PM
RAW's Avatar
RAW
Injection pump failures can happen like that. Most the time an injection pump fails its due to electronics.
Choose readers can be as cheap as $10. Very basic, and will only give the code number, but then you can look that number up.
Old Nov 18, 2012 | 01:29 PM
Rayrod's Avatar
thanks. yea my buddy can get one from his work. some fancy one that will tell me exactly whats wrong he says.
taweste
Aug 29, 2015 02:34 PM
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
