4x4 not turning wheels in front
Old Nov 14, 2012 | 10:37 PM
dodgehendrix's Avatar
Default 4x4 not turning wheels in front
hey there guys I am new to the site. i have a 97 dodge ram 2500 5.9 diesel. so my prob is when i put the truck in 4 wheel drive it feels like it goes into gear and all it dose is turn the drive line in the. not the wheels. im just looking for any input at all on it.
Old Nov 14, 2012 | 11:33 PM
turbo2332's Avatar
vacuum actuator on the pasanger side axle tube is giving you fits
Old Nov 14, 2012 | 11:36 PM
dieselnut73's Avatar
If you look through the forum you will find answers to just about anything that could go wrong with your truck. Check to see if you have vacuum to the front diff if not check on top of the transfer case. Welcome to the site I've learned a lot on here myself
Old Nov 15, 2012 | 07:02 PM
Jamsee251's Avatar
your front aculater could have went out or it can be plugged up .. if you need the 4x4 for temp. and if you have manual hubs then you can undo the 4 bolts and take the fork out slide the ring over and basically flip the fork and it will work i have had my 87 ram charger do the same thing when i was on a trail so i did the temp fix and made it home
Old Nov 15, 2012 | 07:17 PM
daveO's Avatar
Mopar1973Man's Dodge Cummins Articles - Central Axle Disconnect (CAD) System Troubleshooting
Old Nov 16, 2012 | 07:10 PM
DieselObsession76's Avatar
Throw a posi lok on it... one of my favorite mods so far.. cheap and easy aswell as very reliable.
Jsully
Aug 31, 2015 07:55 PM
Alaskabound
Aug 20, 2015 07:00 PM
2FordStrokers
Jan 11, 2015 09:40 PM
2FordStrokers
Tire, Wheel & Suspension
Jan 5, 2015 09:23 PM
