Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
LLY interesting problems
Old Nov 13, 2012 | 09:58 PM
embs200's Avatar
Default LLY interesting problems
My lly will not build prime pressure. The filter housing has been rebuilt and i pressure checked it with fuel outside of the truck. It held its pressure with no leaks. That was with the inlet hose in a 5 gal tank and the outlet plugged.
Inside the truck its a different story. the plunger just keeps on pumping. You can also almost hear the fuel getting returned to the tank or out a leak.(you can hear the pressure being lost) All rubber lines and clamps have been replaced between cp3 and filter housing. I tried priming it with the inlet hose for the filter housing in the 5gal tank which i put in the engine bay. So that eliminates my lift pump, tank pick up, ect...
My question is: Other than the filter housing causing no prime pressure. Could the cp3 itself be loosing the pressure, whether it be a valve or a leak?
I also noticed a T fitting on the supply just before the cp3 that connects to a return line... How does that work???
My truck is in a start then die situation please help!
Dbleo351
Nov 20, 2016 09:34 AM
DODGEARMYGUY
Mar 3, 2015 11:40 AM
Zachbishop
Feb 10, 2015 10:23 AM
Ol Goat
Jan 22, 2015 02:16 AM
duramaxtuner
04.5-05 LLY Performance
Dec 10, 2014 01:56 PM
