best programmer for chip for a 99 24v
Old Nov 13, 2012 | 12:57 PM
98/12v's Avatar
Default best programmer for chip for a 99 24v
i just bought a 99 24v 5 spd wit a dual disc south been hot rod vp a full 4 in exhaust banks exhaust brake fass 150 and 150 hp injectors and a bigger turbo it only has 90,000 on it and has never been chipped
Old Nov 13, 2012 | 03:25 PM
StrokinAndCummin44's Avatar
Smarty all the way!
Old Nov 13, 2012 | 03:54 PM
globalwarmingcontributor's Avatar
If you want something on the fly, check out edge comp or quad adrenaline... both good chips for the money!! they would accommodate the hot rod vp nicely
Old Nov 13, 2012 | 04:18 PM
H.R.D's Avatar
Smarty is a great programmer, it will provide you with about 65 hp over stock. Edge J/A and Quad will give you close to 120 hp over stock. I recommend edge I believe they have a much more stable and trouble free platform then Quad does. Remember to create over 65 additional hp you need to tap the pump wire on the VP the smarty doesn't do that, however, it does create great low end power, where they other two are more mid to top end producers. This is also why so many folks stack with a smarty/edge or smarty/quad.
Old Nov 14, 2012 | 07:20 PM
98/12v's Avatar
Is a quadzilla xzt chip a good one I can get it cheap and a boost fooler
Old Nov 16, 2012 | 08:15 AM
colinheitshusen's Avatar
The XZT is only about a 65hp chip. Wit the upgrades you have, if you really want to take advantage of them and you have guages I would go with an Edge Comp. I have it and it is about as easy to use as it gets. But tapping the pump is a little hard if you dont have a vp stealth cover.
Old Nov 16, 2012 | 08:43 AM
RAW's Avatar
RAW
Edge Comp if you have gauges, Edge Juice with Attitude or Quadzilla Adrenaline if you don't.
JPatt
Jul 29, 2015 03:25 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
gyayo2012
13
Jan 14, 2015 11:29 AM
aoutlaw95
9
Jan 5, 2015 07:21 PM
racer598
Nov 23, 2014 12:52 PM
