47rh transmission acting up.. Need help!
Old Nov 13, 2012 | 11:59 AM
BowHunterLegend's Avatar
Default 47rh transmission acting up.. Need help!
I have a 1995 dodge cummins with a 47rh automatic transmission. I just put it in couple months ago. has maybe 2,000 miles if that. has a stage 2 low stall TC. The TCC solenoid went out so i replaced it. it was a little low on trans fluid but it was still on dip stick right at the ADD level. took it down my lane (1/2 mile) and stopped at the top. gave it some gas try and spin tires a little and now its acting up. I filled it with fluid to the FULL mark and added Lucas stop slip. Now if i ease into the throttle slowly it will spin. But if i jump on it, it just revs high. If i drive down the road i can lock the TC and it takes off. Slowing down if i downshift on the column it slows the truck down normal. if i drive normal, works fine..
Old Nov 15, 2012 | 06:01 AM
captain_stabbin's Avatar
valve body?
Old Nov 26, 2012 | 06:46 PM
does that sound like valve body symthems?
Old Nov 26, 2012 | 11:57 PM
turbo2332's Avatar
could be. i had one that only had first and R and like 2nd in ahalf then it would rev up. converter failer kinda doubt it. what kind of mainline pressure is the pump making? did you do the tranny install? you could have had the converter slip out of the input a bit and bind in the pump drive and jacked the pump dawgs up?
Old Nov 29, 2012 | 12:34 PM
Fox's Avatar
Fox
are you sure you have enough fluid? These things take something ridiculous like 2 1/2 gallons of fluid...
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
