92 3500 Tire Size?
Old Nov 13, 2012 | 10:43 AM
chevyman0013's Avatar
Default 92 3500 Tire Size?
Hey i got a 92 quad cab 3500 6.5 trubo diesel Dually. I found a 4.5 in lift for it from fab tech and i was just wondering if anyone would know the biggest tire size i would be able to fit on the 16 in rims????? I was wondering if anyone had any advice on military tires. I have heard good and bad things. Also are there any other problems i can run into installing this lift?
Old Nov 18, 2012 | 03:59 PM
3194taylor's Avatar
Tire I would go with if you're using the stock wheels is a lt255/85r16 BFG Mud Terrain, it's not much bigger then a 235/85r16 but it won't balloon on the stock wheels. Last thing you want to do is spend $1,500+ on new all terrains and have the fronts scallop overnight because they're on a 6.5" wide wheel.
Old Nov 19, 2012 | 01:30 AM
Ok dam so I guess the 37's I found on craigslist is just a bad idea waiting to happen huh? If I wanted to go bigger on the tires what would i have to do besides get new rims?
Old Nov 19, 2012 | 11:19 AM
3194taylor's Avatar
You can put whatever tire will fit, I was just saying to fit on the wheel properly 255 is the widest you'd want to go. I've put 12.5" wide tires on 6.5" wide wheels, but duals won't clear with that wide of a tire
Old Nov 19, 2012 | 11:53 AM
Would you know anything about the spacers they make and how they work. I heard they work up to a point. Are there any problems that come with spacers?
Old Nov 19, 2012 | 07:58 PM
tiremann9669's Avatar
Yea your wheel studs will be too short and when you load enough weight on it your wheels will come off goin down the road. Other than that they're great
salty4life
Aug 20, 2015 10:46 AM
B737 Capt
Jun 9, 2015 06:34 AM
dallasca
28
May 26, 2015 12:58 AM
LB7yooper
Chevy/GMC Duramax 01-04 LB7
Mar 23, 2015 11:33 AM
LikeTheFabric
Ford Powerstroke 2011-Up 6.7L
Mar 10, 2015 01:18 PM
