1995 fuel problems
Old Nov 12, 2012 | 04:24 PM
jps51248's Avatar
Default 1995 fuel problems
Having low fuel pressure on a 1995, Cummins of course. Installed new overflow valve. Helped a little. Was suggested I check vacuum at the lift pump on back to fuel tank. Looking in the shop manual for these trucks, it mentions a special hose adapter tool, a tee. Gives part # as 6837.So far, haven't found this tee. This is on page 14-108. Anyone know where I could get this tee? Or any other way to check for a leak from the lift pump to the tank. Trying to avoid removing tank. Have not tried new lift pump. Want to keep it mechanical. Only 70K on the truck. Wouldn't think the pump would be out. Fuel heater is gone, screen there is clean. 10-15# at idle. Going down the road it drops to zero. Can only get to about 70-75 MPH . Could use some help!! jps
Old Nov 12, 2012 | 06:27 PM
South Texas Goat's Avatar
lift pump
You put a lift pump in your tank, or someone else?
Last edited by South Texas Goat; Nov 12, 2012 at 06:27 PM. Reason: Automerged Doublepost
Old Nov 12, 2012 | 09:01 PM
jps51248's Avatar
Originally Posted by South Texas Goat
lift pump
Must have misunderstood my post. No lift pump in the tank.. Just the old pump on the side of the block. Mechanical. jps
gillespie3033
Chevy/GMC Duramax 01-04 LB7
29
Jun 25, 2015 03:51 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
J. Nick
Apr 24, 2015 01:13 PM
moneypitk5
Feb 12, 2015 11:01 AM
