timing injectors???
Old Nov 12, 2012 | 02:30 AM
Dodge Ramer's Avatar
Default timing injectors???
Ok guys hope yall can help me if i had a 91 dodge can i put a 96 ppump on it with havein to put biger injectors in it or changing the timing someone told me you did but i dont trust him so plz anwser back
Old Nov 12, 2012 | 08:57 AM
turbo2332's Avatar
injectors will have to be at least re popped, the pressures are much higher. and if you switch injection pumps you will need to set your timing up. so no is the answer
Old Nov 12, 2012 | 09:57 AM
cumminskid92's Avatar
You will need a new front cover and pump gear for the p pump. Also if you use the 1st gen injectors you will have to get adapters to hook up the lines. By the time you did that and had the pop pressures reset you might as well buy new injectors
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
SMatyac
Nov 15, 2014 07:35 PM
