01 cummins/no power when cold
Old Nov 11, 2012 | 10:00 PM
beaumid10's Avatar
Default 01 cummins/no power when cold
i have a 2001 cummins with 175,000 miles on it, it has no power when cold but when warm she runs great. any suggestions?
Old Nov 12, 2012 | 12:06 AM
Bryce's Avatar
How cold is it where youre at? Cummins will be a little sluggish until it warms up. You might try a thinner oil in the winter. I run Rotella t6 5w40. I also plug my block heater in and have the outlet on a timer to start heating it up a couple hours before I leave for work. If its an auto its probably time to change fluid and filter.
Old Nov 12, 2012 | 06:18 PM
MBFD 592's Avatar
does it feel like you have a dead pedal? if so check for codes, it might be the injection pump.
Old Nov 12, 2012 | 06:52 PM
H.R.D's Avatar
Usually the injection pump, if going out, will work good when cold then start acting up when it gets warm.
Old Nov 13, 2012 | 06:33 PM
MBFD 592's Avatar
My truck was the opposite. Dead pedal when it was cold then when it got warm it ran fine. My computer was also showing me a p216 code.
Old Nov 13, 2012 | 06:42 PM
greed's Avatar
When the outside temp was below about 38deg, mine would blow white smoke and run cruddy until warmed up. Turned out to be cam position sensor.
Old Nov 27, 2012 | 08:04 AM
dws4wsdr's Avatar
Default Same problem
beaumid10,
I should have looked a little further in the threads before posting mine. I have the exact same problem. What all have you done to trying to fix it?
explorer197143
Dec 28, 2014 01:14 PM
el_gringoo
Dec 14, 2014 11:03 PM
