trans questions
Old Nov 11, 2012 | 07:49 PM
dango's Avatar
Default trans questions
I have a 47re that was just installed 10,000 miles ago. seems like the torque converter is already starting to slip. I have been debating the idea of converting it to a manual. I have no intentions of ever racing or pulling my truck, I just want a good dependable truck. Is this a good idea? if so what trans would be good to go with?
Old Nov 11, 2012 | 09:54 PM
BarryB's Avatar
When you say, installed 10k ago. Did you have a stock replacement torque converter put in?Thats probab;y most likely your problem. I would double check that first before going the whole conversion route. You can get a better torque converter that will hold up to all your needs. such as a single disc or even a triple disc.
Old Nov 11, 2012 | 11:02 PM
Bryce's Avatar
Does it only slip while cruising (tach jumping 200-400 rpm)? If so all you need is an apps noise isolator. 94 05 BD Diesel 5 9L Dodge RAM Apps Noise Isolator Automatic Transmission Fix | eBay
A well built auto is just as good if not better than a manual
Jake9473
Jul 22, 2018 08:19 AM
PA 24valve
Aug 31, 2015 07:39 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
