air vents
Old Nov 11, 2012 | 05:30 PM
gregt1989's Avatar
Default air vents
hey guys i have a donor truck to convert my truck to have vents in the dash and ac. any of you guys have some links to show me what all i need to take out to do the conversion.
Old Nov 14, 2012 | 01:13 PM
1993firstgennewbie's Avatar
well this isnt gona be easy you just need everything that hs to do with ac, compressor, switch, wiring, condensor, evaporator, lower water inlet since that is what the comp mounts to and lower radiator hose, new AC belt, belt tentioner pulley AC pulley is flat , you should probly replace your heater core as well since you will have the dash off,you will also need a brand new orphase tube and dryer, also you should probly convert the freon to r134a since it is verry expensive to charge it with R12. I think im even forgeting stuff also its a PITA to install the compressor
Old Nov 14, 2012 | 04:22 PM
1999 Sport Cummins's Avatar
^^ hes right and if your going to go that far with it, you will prolly want to remove the windshield and pull your dash just so you have more room, will make the inside coversion much easier!
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
petew
Oct 25, 2014 09:29 PM
