need some help if ya'll dont mind.
Old Nov 11, 2012 | 10:22 AM
DevilDog6154's Avatar
Default need some help if ya'll dont mind.
so my oil pan is leaking and i want to replace the gasket so do i have to pull the motor? or can i simply just unbolt it and pull it out?
guess thats a dumb question? it just doesnt look like it has enought room to drop and move out the way, and i dont want to unbolt and mess up the old gasket more and then not be able to change.
Last edited by DevilDog6154; Nov 11, 2012 at 10:22 AM. Reason: Automerged Doublepost
Old Nov 11, 2012 | 05:48 PM
fordidipower's Avatar
from my understanding ( eve though ive never done it) you loosen motor mounts and jack up the motor and pull it out. could be wrong though........
Old Nov 12, 2012 | 11:26 AM
ok so i dont have to pull it just lift it up thanks.
Old Nov 13, 2012 | 08:42 PM
blacksmokeaintbroke's Avatar
ive done it with out pullin the motor its a rear bitch,you gotta unbolt the body and set on 4x4 un bolt motor n tranny,and do a lot of jacking,lifting,prying.then drop pan but will not come all the way off just drops down about 5-6 inches but enough to remove old gasket and then you are able to snake the new gasket back into place,now i think about it i wouldve been easy to just pull the dam motor
Old Nov 18, 2012 | 09:17 AM
yea sounds like it. thanks
Justin Carpenter
Sep 14, 2015 02:32 PM
cummins Pride
Sep 9, 2015 10:55 AM
LadyyD
Jun 16, 2015 03:40 PM
