PD421
Old Nov 10, 2012 | 09:12 AM
sik6's Avatar
Default PD421
Hey everyone im asking for a little help, check engine light came on so i checked with my smarty jr and came up with a PD421 and i can't seem to cross reference it. Any and all help would be greatly appreciated.
Old Nov 10, 2012 | 06:22 PM
South Texas Goat's Avatar
Did you look at code PO421 instead of PD? It's the warm up catalyst below efficiency threshold.
Old Nov 12, 2012 | 05:51 PM
sik6's Avatar
I cleared the code and ran the truck a good bit and the check engine light has stayed off. I checked again and the code is correct but it seems to be very uncommon just my luck, the only thing i can figure is it had set for about 2weeks and the temp dipped pretty good and messed with it. I also have some corrosion on my batt cables just haven't had time to clean them so that could be part of my issue as well.
Old Nov 12, 2012 | 06:04 PM
Dang weak battery will get everything off. Hopefully that's all it is.
