what should i do next
Old Nov 8, 2012 | 01:50 PM
mattestcali86's Avatar
Default what should i do next
i have a 96 12 valve it has a k&n intake 5 inch turbo back exhaust and have the stock fuel plate slid up where should i go next
Old Nov 8, 2012 | 02:11 PM
prowler48's Avatar
If I were u I would do a lot more to the pump because it's free power and pretty easy to do. there's some good write ups on here of various pump mods. but if you're itching to spend some money then i'd say get a 4k governor spring kit and some valve springs.
Old Nov 8, 2012 | 02:48 PM
what do youi know about the star wheel like what way do i turn it for more power and how much do i turn it
Old Nov 8, 2012 | 08:02 PM
somkincummins95's Avatar
towards the motor is more power turned mine and i saw a diffrence u can turn it as much as u want till u find the right setting but the more u turn it the worse milage u get BUT i would not turn it more than a 1/4 turn WITHOUT an egt gauge cause it does run a little hot especiallly if your pulling something
Old Nov 11, 2012 | 05:22 PM
x--TrainWreck--x's Avatar
Yep and after all the afore mentioned mods some stage 2 injectors will work wonders for ya! Even giving you better gas mileage once the excitement wears off and you can keep your foot out of it!
Old Nov 11, 2012 | 07:22 PM
Bigg Redd's Avatar
First and foremost, make sure your lift pump is up to the task.............
None of those mods will be worth a hill of beans if your LP takes a dive and takes your IP with it...........know whatamean?
Old Nov 11, 2012 | 07:49 PM
what kind of injectors do you recomend and how much hp should it give me
