new turbocharger
Old Nov 8, 2012 | 08:50 AM
CUMMINStagetcha19's Avatar
Default new turbocharger
I'm wanting to upgrade turbos, or make my H1C better. I've got an hx40 rebuild kit. and HX40 wastegated turbos are like 300 bucks on ebay. my truck is a 92 auto, making the H1C a 21cm housing. instead of piecing together, would a whole new turbo be a better idea. and do we have a T3 or T4 flange? i'm shooting for 250- 300 ponies, truck is all stock right now. any opinions please.
Old Nov 15, 2012 | 09:18 PM
Screamin' Metal's Avatar
250-300 is easy to get for very little $. Turn up your screw, replace your governor springs, build yourself a cold air intake, run a big pipe out back, regrind your fuel pin, POD injectors are nice, the 3 piece expandable exhaust manifold, along with your new turbo ought to get you there no problem.
Gotta get a little rpm up in that motor, should be do-able for less than $700 if ya choose wisely....alot less with good used parts....
Old Nov 18, 2012 | 02:06 PM
splitnrag's Avatar
I'm going down this path. I'm looking at a 3200 rpm spring, Denny T Pin, HX40, 2nd Gen Liftpump, stage 4 injectors and 4" out back. I too am looking for 300+ and think this will be the ticket. I will be over $700 but will do it in stages. I already have a fresh air box in place and I will probably make a new intake side with a 6.0l intercooler. I hope it will be a good combination of power, fuel economy and playability.
Old Nov 18, 2012 | 03:35 PM
bladeyamaha's Avatar
POD injectors run hot n are not that great of an upgrade IMO.
Old Nov 20, 2012 | 10:11 AM
tampabaybill's Avatar
Get the 60mm compressor upgrade and the 14cm trubine housing upgrade, 5x12 nozzles from DAP, 4inch turbo back, BHAF, M3 pin, TFOD shift kit and a good converter, bump timing 1/8 and drive it. You will have over 300hp, it will spool quick and have about 35 lbs of boost and run cool egt wise, have good economy and little smoke if you tune it right. Be a responsive daily driver and suprise some guys with late model stuff.
Old Nov 21, 2012 | 03:30 PM
Scott Mason's Avatar
He351cw upgrade is easy change over for about $550 very fast spool up
Old Dec 3, 2012 | 01:36 PM
jkidd's Avatar
We have combo kits available as well if you want turbo and injectors. We also have 5x.013 nozzles and some in a SAC style.
robbyS
Apr 16, 2015 02:22 PM
F1nch
Mar 24, 2015 12:15 AM
GreenDieselF
Oct 20, 2014 02:05 PM
