03 6.0 diesel: EGR ??
Old Nov 7, 2012 | 11:24 PM
Oldesalt's Avatar
Default 03 6.0 diesel: EGR ??
Is there any downside to replacing the factory EGR with a good bulletproof aftermarket?
I am in a no-emissions test area and so could just delete it. Any reason to delete or not to delete?, other than emissions tests??
Old Nov 8, 2012 | 01:28 AM
jeffa6980's Avatar
Deleting it would be your best bet if you dont have emission testing. Better reliability for your truck. and one less thing to deal with or have to trouble shoot if you have a problem
Old Nov 8, 2012 | 03:17 AM
dkapp0802's Avatar
i just welded mine completely shut and dam it woke my truck up.
Old Nov 8, 2012 | 11:36 AM
Oldesalt's Avatar
Default EGR delete or new and better??
Thanks, Jeff and D Kapp. D Kapp: when you say "it woke up your diesel", do you mean you noticed an improvement in performance?
Old Nov 8, 2012 | 02:30 PM
Mdub707's Avatar
I noticed a SLIGHTLY quicker spool up, but more importantly when I pull into a parking lot, the EGT's drop way quicker on the gauges with the full delete. The solid up-pipe makes sure all exhaust is getting directed at the turbo instead of scooping some for the intake. Blocking this path off is the best if you live in an area that doesn't require emissions testing IMO.
Old Nov 8, 2012 | 02:49 PM
bobfbigman's Avatar
with the 03 you just need the basic delete, you don't need a new uppipe like the 05and up do. the 03 and04 do not have a restriction in the uppipe, just need the block off for it.
Old Nov 8, 2012 | 04:13 PM
camper42's Avatar
I am a newbie here and to trucks in general. I have an 03 Ford F350 6.0 and have deleted the Erg. Has anybody put a cummins engine in their Ford. I have heard from my mechanic that the 6.0 will be a problem child. I should have found him before I bought it I guess, but I love the Fords. I use it primarily to pull a 30 foot camper
thanks
Old Nov 8, 2012 | 05:13 PM
bkmac's Avatar
thanks
Welcome
I also was/am a newbie when it comes to diesels.
I have over 173,000 miles on my stock (except for coolant filter) 6.0 PSD and just now have been having some problems. There are guys that have more than that on their trucks with no problems.
Keep up good PM on the truck and use the proper lubricants and filters and that will help eliminate a lot of potential problems.
If you do have a problem you won't believe how good the help on this forum will be. Just read some of the post on what info that will be wanted before questions can be answered.
You already have an EGR delete - I would consider a coolant filter.
Old Nov 8, 2012 | 08:38 PM
Oldesalt's Avatar
Default EGR delete or upgrade stuff
Thanks to all of you. Awesomely helpful.
The comment on a coolant filter is not mentioned much but my Ford diesel guru says that is really one of the less expensive but necessary additions. Reason: any small particles, sand from the block casting, rust or whatever circulates until it gets stuck in some of the small places like the oil cooler or EGR radiator fins. He says that all of the semi trucks use them. Takes a small spinoff filter just like all of the rest of our filter systems.
Old Nov 9, 2012 | 07:12 AM
Mdub707's Avatar
Yeah most of us have them already. Dieselsite.com has them and so does Sinister diesel, pick your favorite color, they're pretty much the same thing.
