Bad vp or what??
Old Nov 6, 2012 | 10:11 PM
Dodge Ramer's Avatar
Default Bad vp or what??
i have a 02 3500 i put 150+ injectors in it and burned up my old vp it was a 245 HO so got a used pump a 235 and put on the truck it starts fine but when i push pedale all the way to the floor it starts missing and popping it sounds like its out of time but i have pulled the pump and put it on again so i know its not and it has 10psi fuel pres anything you know will help
Old Nov 7, 2012 | 12:07 AM
H.R.D's Avatar
Very well could be a bad USED IP. Do you have a good aftermarket LP on it? Does it throw any codes? Have you checked for fuel leaks, could be air getting in.
Old Nov 7, 2012 | 05:00 PM
Yes I have looked for leaks don't see any and I have a glacier diesel belt driven Lp don't know about the injectors I got them online and they didn't have a name on the package
Old Nov 8, 2012 | 11:29 AM
H.R.D's Avatar
I am leaning towards injectors my friend. I would pull them and have them pop tested and flow matched. Have you checked for codes?
It could also be your IP too, I would have that bench tested.
|WYG|SS
Jul 26, 2015 11:18 AM
|WYG|SS
Jul 4, 2015 08:31 AM
Cumminsmoney
Mar 20, 2015 02:33 AM
Feb 5, 2015 12:10 AM
12vbomber
Nov 11, 2014 10:58 AM
