more power?
Old Nov 6, 2012 | 09:37 PM
somkincummins95's Avatar
Question more power?
i have a 95 12v w/ 95hp fuel plate; 4k gsk; built trans for 600hp; egt, boost, and fuel psi gauges. i can get an 62/65/13 turbo but i have an hx40 now. how much power can i push? and whats the best way to get it? i hear about afc housing and a star wheel but i have no clue what or where that is can anybody help?
Old Nov 6, 2012 | 11:29 PM
turbo2332's Avatar
search function
the HTT is a WAY better turbo!
Old Nov 7, 2012 | 05:12 PM
what about injectors?
Old Nov 7, 2012 | 06:49 PM
HydroElectric's Avatar
As far as power, my guess is 600hp.
ball busting.
Old Nov 7, 2012 | 07:11 PM
whats the most power i can get with an hx40?
Old Nov 8, 2012 | 03:20 AM
captain_stabbin's Avatar
450 ish
Old Nov 8, 2012 | 07:46 PM
perfect thats all i need whats the brst way to reach it?
Old Nov 10, 2012 | 12:44 AM
huricane's Avatar
5x12 injectors afc mods 4 gsk and 60lbs valve springs and a good bit of tuning will get you there but do a lot of reading first
Old Nov 12, 2012 | 10:48 PM
Al31031's Avatar
the 5x12 would be very nice with a moderately upgraded turbo your gonna need a bit more boost to so a boost screw adjusted correctly could help out tremendously and crank that pump up, bumping that timing to like 19* maybe 19.5* mine is at like 20* but that was an accident but runs really well i thought it would be to much delivery valves while your doing the timing i got a nice set from ddp intake for sure star wheel is easy just could take a lil trial and error to get it perfect gsk probably made the biggest difference in my truck but i would go 3k 4k is a bit to much i thought and you don't need 60lbs springs . I also recommend doing a tc lockup switch that makes a big difference too, i would prolly take care of the kdp to while your doing the timing why not ya know.
Old Nov 13, 2012 | 06:30 PM
i tried to adjust the strar wheel but it would not move towards the moter it would only turn away from the motor any ideas? whats the boost screw? how do i adjust it?what size delievery valuves do i need?
