2006 6.0 no start
Old Nov 6, 2012 | 08:39 PM
craneman4115's Avatar
Default 2006 6.0 no start
Help have a 2006 F350 6.0 all my checks are in ranges but still no start only code is # 3 glow plug
Old Nov 7, 2012 | 01:42 AM
jeffa6980's Avatar
hey were going to need a whole lot more info to help you. Is it cranking at all? Any smoke coming out? Do you have a scanner? What mods are done to your truck? What happened before it stopped starting?
Old Nov 7, 2012 | 02:11 AM
dkapp0802's Avatar
is it happening when cold and hot? just cold? just hot? if its hot i just went through this. replace your stc fitting on your hpop (high pressure oil pump) standpipe and dummy plug O-Rings. that will fix if. ifs its cold probobly lpop (low pressure oil pump). if you can do it yourself then do. if not then prepare that ol' check book
Old Nov 7, 2012 | 08:39 AM
Mdub707's Avatar
Start by reading here: https://www.dieselbombers.com/ford-p...questions.html
Then we can help answer your questions.
Cavnar
Sep 9, 2015 07:18 PM
Accubuck
May 7, 2015 04:46 PM
cjgregory
Mar 31, 2015 01:45 PM
dandbmcc
Mar 14, 2015 11:05 PM
thumperf350
Jan 8, 2015 12:55 AM
