1st gen no power?
Old Nov 6, 2012 | 11:59 AM
blackout's Avatar
Default 1st gen no power?
so I have a pretty much stock non intercooled 1st gen. pump is turned up a little, straight pipe, and cold air intake.Has the 727 torqueflite transmission.
ive had the truck for a while . but recently it fell flat on its face. i will be on the freeway going 60 and its wide open.
feels like something is luggin it down . doesnt feel snappy. barely smokes now. my tranny fluid is not burnt. (some metal shavings on the magnet in the tranny pan..but was pretty clean down there.)
does the throttle valve cable need to be adjusted?
or does it seem like not enough fuel?
(i used to have 30 pounds of boost wide open..now im lucky if i get over 10)
any help is appreciated.. just want my power back!
Old Nov 6, 2012 | 12:09 PM
BC847's Avatar
Originally Posted by blackout
barely smokes now.
- Check the AFC's boost reference tube and be sure it's connected and not leaking.
- When was the last time you replaced the fuel filter?
Old Nov 6, 2012 | 12:36 PM
blackout's Avatar
it was about a month ago. fuel was clean. got all of the air out of the lines too. ill check the boost line right now
Old Nov 6, 2012 | 01:27 PM
12 valve and proud's Avatar
What's the idle feeling like? Choppy or luggish?
Old Nov 6, 2012 | 06:05 PM
cumminskid92's Avatar
Boost leak or possibly bad shut off solenoid? Any white smoke while accelerating
Old Nov 10, 2012 | 01:39 PM
blackout's Avatar
it starts perfect. but i did notice as i acclerate in park.. you can feel its a little choppy...i wanna install a fuel pressure gauge.. bad lift pump? probably needs replaced anyways the truck is 20 years old
Old Nov 27, 2012 | 07:49 PM
peterbuilt1024's Avatar
I have about the same problem so please post if you find out what your problem is and I will do the same. Thanks.
Old Nov 27, 2012 | 09:26 PM
bladeyamaha's Avatar
A new lift pump would not hurt. Here's a great upgrade. Reliable Company too. > 89-93 dodge 1st gen low pressure piston lift pump | eBay
Cdog121
Nov 16, 2015 01:49 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
ajpt6.9
Dec 4, 2014 12:06 PM
myago92
Oct 17, 2014 08:50 AM
