help 93 ford diesel smokes
Old Nov 6, 2012 | 11:24 AM
bodyman36's Avatar
Question help 93 ford diesel smokes
new glow plugs new injectors still acts like it dumping fuel... at idle seems its ok but when i give it throttle it smokes like its on fire white heavy fuel smoke.. help help
Old Nov 6, 2012 | 03:18 PM
8seconds's Avatar
Your truck needs to be timed, sounds like the IP is retarded. How many miles are on the clock, if over 120,000 miles; you may need to invest in a new IP. When you changed the injectors, the pump had been used to the old worn ones and now you have this problem.
You will need to find someone that has the proper timing equipment for these trucks to do so, don't rely on someone that says that they can time it by ear....
Old Nov 6, 2012 | 04:52 PM
bodyman36's Avatar
Question
so even with the new glow plugs and injectors it might be in the timing in the ip evenb though we never moved it? the truck was running like this when it got here had to be eithered to start, and after the gpr and glow plugs and injectors ,, i see what you mean we will check the timing of the ip is the gpr on thios one supposed to clcik as soon as you tune the key on?
Old Nov 7, 2012 | 09:11 AM
8seconds's Avatar
Yes the GPC should come on even when warm, but only for a breif second. The cold start cycle should consist of about 10- 15 second of cycle time. After the light goes off, it will cycle for a few seconds ( you will notice your voltage meter bounce) after craking to help with clearing the intial smoke from cranking.
Old Nov 22, 2012 | 10:50 AM
Kalashnikov's Avatar
If the IP was not changed with new injectors then the timing will be off since the IP already has some wear.
You could try adjusting the timing on the pump yourself and try to get it so it atleast runs better through trial and error.
Angeliruo
Diesel Engine Conversions
Oct 8, 2015 08:24 PM
Dec 10, 2014 08:10 AM
dba
Nov 26, 2014 10:28 AM
Oct 13, 2014 08:10 AM
