oil pan gasket ultra gray routing
Old Nov 4, 2012 | 09:25 PM
iceman1404's Avatar
Default oil pan gasket ultra gray routing
Putting in a new oil pan gasket and was wondering if the ultra gray just needed to be routed along the 4 holes of the back of the gasket or should I go around the entire gasket. Also both sides or just one? Thanks
Old Nov 4, 2012 | 10:01 PM
Bryce's Avatar
I put a thin coat of black permatex on both sides all the way around. Just dont make it so thick you get a bunch squeezing out inside the pan. Be sure to give it a few hours to cure before adding oil and driving it.
Old Nov 4, 2012 | 10:35 PM
iceman1404's Avatar
Would it be a good idea at all to put some permatex shellac on the block with silicone on the seams of the front cover and rear main seal cover and then shellac on the oil pan side of the gasket?
freak-n-diesels
Aug 23, 2015 06:47 PM
CRCSI
Mar 29, 2015 11:26 PM
98cummins
Jan 29, 2015 08:23 PM
BCOWANWHEELS
Wanted To Buy (WTB) - Used
Jan 7, 2015 03:42 PM
98cummins
Dec 9, 2014 10:14 PM
