Urgent please help
Old Nov 4, 2012 | 05:15 PM
cheer's Avatar
Default Urgent please help
I was driveing down the highway and something just let go,its like it just droped outta gear or something?? Does anyone have any ideas? Is my tranny done ?? I wasnt romppin on it or nothin? Please help.
Old Nov 4, 2012 | 05:24 PM
1999stroker's Avatar
Will it go into any gear at all? Reverse,1,2 ?
Sent from my DROID BIONIC
Old Nov 4, 2012 | 06:00 PM
cheer's Avatar
Nothing no gears just park??
Old Nov 4, 2012 | 06:03 PM
Check your linkage and fluid see if it smells burnt or any metal shavings.
Old Nov 4, 2012 | 06:04 PM
Are all the drove shafts in tact
Old Nov 4, 2012 | 09:00 PM
RAW's Avatar
RAW
So many things it could be. Input shaft, T/C to flex plate bolts, oil pump, low oil. As suggested above, check the fluid level. It will be high if any of the above happened. You can remove the inspection plate and look up there for signs of failures. The T/C shouldn't rotate freely of the engine.
Old Nov 4, 2012 | 09:25 PM
wilke12V's Avatar
I kinda had an issue like this. Ended up being the shifting fork in the t case. Rebuilt it and all was well, I put it in 4wd and it drove went like a mile put it back in 2wd and it got me home enough to take it apart and try it again. Hope this will narrow it down
But like you said. I had no gears except park and it made a terrible noise when I tried to move it
Old Nov 5, 2012 | 08:33 AM
cheer's Avatar
Checked levels,,looked low so i put some in andnothing still not sure if i put enough in tho,,oil doesnt smell burnt looked good..if i didnt use atf4 would that wreck it iused oil that said it was good for allision trans?
ALWAYSREADYROB
Oct 5, 2015 10:22 AM
Backhoeman
Jan 3, 2015 12:53 PM
