Battery drain?
Old Nov 4, 2012 | 11:48 AM
soggybottom's Avatar
Default Battery drain?
I am wondering what amount of draw I should have on my batteries with everything turned off.
I disconnected both positive battery cables and checked with a test light between the positive terminal on one battery and a positive cable and the light came on. I then tested the amperage and with the meter set at 10a it read .11. Is this normal? It seems high.
I disconnected all of the positive connections at the relay on the passenger fender and it didn't change anything. I also went through and pulled every fuse and still no change.
Any input appreciated. Thanks.
Old Nov 5, 2012 | 09:11 AM
7.3 idi 1990's Avatar
If your batteris drain like my autocraft, Group 65 did, I would check the glow plug relay, thats what done it on mine, I just replaced the stock system with a manual button, and it work flawlessly.
coryfast
Jul 23, 2015 09:00 AM
rodbuilder
Jun 26, 2015 12:48 AM
carid
Diesel Bombers Sponsors
Dec 4, 2014 05:06 AM
Baradium
Nov 21, 2014 08:20 AM
Kentonjl
Sep 30, 2014 07:22 AM
